GSLENK
- 1,416
- 55
- May 25, 2011
DC,
Maryland
Sure we have a few threads on what a BLT should result in, but we don't have much real world data.
If anyone can post up a log of a very good boost leak test I would greatly appreciate it. If you want to clip it for me, I want a few seconds from the max MAP pressure, all the way down to "0" pressure.
I took a log of my latest boost leak test. I started at ~19 psi. My compressor couldn't keep up with the leak that happened at the inlet of the turbo (my BLT tester sucks, so overall this data is skewed terribly).
In a nutshell, I exported my data to excel, and sampled it by interval (to remove extraneous computation time). Then I plotted MAP vs time, and did some analysis.
My whole system with a crappy tester (that audibly leaks itself at ~14psi probably sooner) took a little over 2 minutes to leak down from 19 psi to 0 psi. I was curious to see what effect this had at various boost levels, and how much performance is really hurting.
By doing an 8th degree polynomial regression , I was able to mimic my test results almost perfectly with an equation, from about 1-100 seconds of the total 0-180 seconds logged. Then taking the derivative at select points I can estimate my psi lost per second.
Here's the end result of my calculations (how much psi lost per second @ different pressure levels. the rate is decrease in psi per second)
@18 psi, lost .919 psi/s
@16psi, .78psi/s
@14psi, .63psi/s
@10psi, .347
@5, .141
@3, .09
@1, .03
Again this is heavily skewed, I am just trying to find out what a real acceptable boost leak is, and find how much an acceptable level of leak can affect performance.
Anyone want to hook it up with some good boost leak down logs?
@16psi, .78psi/s
@14psi, .63psi/s
@10psi, .347
@5, .141
@3, .09
@1, .03
