Blowthrough setup with front mount, turbo question
cmptrphreak
194
Jan 7, 2005
Chicago, Illinois
If I got a blowthrough setup with the 3" maf and translator and mounted a starion intercooler in the front using custom made piping the filter for the turbo Are there any more lines or anything goes through it ? Is it possible for me to mount the instal where the stock sidemount was?
huh? :confused:
Gee instead of acting like a dumb *&^% :toobad: Just ask him what he means? I would imagine that he would be asking would he be able to mount the translator where the Side mount was?
I didn't get the sentance either but make what you can out of it and ask him if thats what he is asking. :thumb:
Maybe he's asking if he can put the air filter where the stock side mount was?? :barf:
You can mount your air filter in the stock Sidemount location.
If you wanted to know if you would mount your translater there, you could too if you wanted to. But I see no reason for anyone wanting to do that.
:rolleyes:
I have my air filter mounted where the sidemount was to get the turbo cool air. The blow thru MAF is in a dejon upper IC pipe that was modified to work with my short route piping. I bought the 6'extension harnesses so that my Translator is mounted on the console below the radio. I had to drill a hole over the shifter cables where they go through the firewall for the harnesses to get to the inside of the cabin. Much easier to make adjustments with the translator in the cabin!
You do need to make yourself more clear with your posts. Mark
I have a pro-m unit in my car so I didnt need to run more wiring becuase it comes with enough to mount everything in your cabin. Boy I love this setup!
