Blown headgasket or Bad Rings?
force_feed
323
5
Jan 31, 2008
Katy, Texas
I'm buying a 90 Talon from a friend of mine with a rebuilt motor with about 3k on it, and I want to get an opinion before I tear it apart to fix it.
The cars compression is 90 across the board. He thinks its the head gasket because the car ran hot on him a few times before he stopped driving it.
After the initial compression test, I poured about a cap full of oil in each cylinder and did the test again. This time the results were about 120-130 in each cylinder.
With that being said I think its the rings....but I could be wrong. What do you think?
It seems odd that all four would be so consistent if it were a HG. This was probably a cold test? That will generally throw off results.
If the oil added boost the pressure in each cyl, then it most likely the rings.
But a leak down test will tell you instantly.
If you can get it cheap then i say go for it and rering it.
90 psi was at operating temp.
Yea I can get it pretty cheap.
Might as well rering it while you've got that much torn down. I'd have the head checked since you said he overheated it a couple of times. Our heads warp easily.
