blower motor not getting power
im faster
Jun 9, 2004
miamisburg, Ohio
ok so.. this is on my 99 GS...
i hot wired the blower.. and it turns on and works great..
i dont see any blown fuses under dash OR hood..
maybe a relay???
if so where is it??
also..
does anyone have a picture of a fuse box cover for under the dash...
You are probably dealing with a blower motor resistor. They usually fail but will leave high functioning but sometimes they can completely go out. Now I haven't looked to see where mine is exactly but the are generally right by the blower motor/ hvac box under the dash. There will be a harness going into it and it might have two or three screws holding it in. But first also grab a test light and pull that harness and cycle through your fan speeds on the fan switch. You should see the light turning on and off at different pins when you turn the switch. That will just rule out the switch before you buy a resistor.:thumb:
