Big16g
InjenTalon96
242
Oct 12, 2003
Plainville, Connecticut
hey i just picked up a new big16g and put it on my 90 gst, with stock injectors i heard i could only run 14psi max psi....is that true?????
blcknspo0ln said:
huh?
i have no other fuel mods but a 190 pump and run 16.5 psi daily *edit* i didn't check, but i wouldn't run more than 13-14 psi if you're ATX with the 390s
now that you mention that hes auto, keep the boost below 12psi...in other words run as low as you want just dont do over 12psi. If you get manual cams and injectors youll be able to run around 15-16psi with a 190 pump.
Andrew
ya im 5spd, so what could i run safely without leaning out????
injectors are overrated :p I ran 20psi on my big 16g all the time on stock injectors and a walbro 255 pump, never had a seconds problem out of the motor.
my friend ran a 7.86 @ 92 mph on stock 450 injectors and a greddy 18g @ 25 psi!!!!!!!!! his motor did finally gernade.
