Big Dumb Newbies Question
It is to run an external gate off the o2 housing. You take out the internal gate and flapper and port the shit out of that wastegate hole and you control boost that way... It is a alternative to using an ext gate off the manifold.. The other peice that goes back into the o2 housing is so it is recirculating back into the exhaust instead of being loud as shit
It's for an external wastegate. You can weld the flapper on your internal shut and mount an external onto the o2 dump. They sell them without the wastegate fitting, I have one :)
You dont weld your flapper shut on these... You remove the flapper and port the hole out and the external gate is the new "flapper" persay..
Yeah my bad, I'm thinking of something else. ^ is right I thought about that as soon as I posted it.
Oh ok I see it now. Its just so the wastegate dumps back into the exhaust rather then atmosphere. Thanks
  • Wanted 6 bolt NT water pipe
    • chrisman287
