1G big brake upgrade for 90 NT
samuraitekno
267
Aug 15, 2002
Dayton, Ohio
so am i missing something here? i purchased a pair of 2 piston calipers from someone on another website and went to put them on and the brackets are way off. I read on the vfaq that one year 95 had banjo bolts instead of the screw in brake lines but i didnt read anything about the bolt holes in the bracket not matching up to my hub. Am I just out of luck or did i just get the only 2 piston calipers that do not bolt right up? and second question is can i just find the correct brackets and use the calipers i bought?
The same thing happened to me once. I'm pretty sure they were not from an Eclipse. Maybe a 3000gt or stealth, but I remember the holes were about 1.25" off. I'm pretty sure you can just get new brackets.
