eclipse98GST
- 89
- 1
- Mar 12, 2004
Florissant,
Missouri
Ive narrowed it down to two selections after doing a lot of research on the subject. Im not very educated on trannys so i would like your opinions. I currently have a TRE tansmission with Quaife Diff in my 98 FWD, i use Penzoil Sycromesh in it and my up shifts are clunky and the tranny does not shift as smooth as i would like. I live in St. Louis MO so the temps now are around 70-90 degrees. Which fluid would you recomend i put in, BG sycromesh II or a Redline Fluid (pleas specify which redline fluid) or even a combo of the two?
Thankyou for your help!
