best tuning
90rslaser
266
Apr 1, 2008
cheyenne, Wyoming
ok guys im trying to find out what would be the best tuning software for me? i have a 1g talon tsi awd. it has pte 580 injectors, sbr ported and clipped 20g, ported 2g manifold, dejpon intake, throttle body elbow, and 3" turbo back. do you think the maf-t with 3inch gm maf, afc(turn nob style) would be good? or what? i also have a safc-1 i could use. what do you guys prefer to use for tuning UNDER 1,000g's. and also will a 2g e-prom ecu work on my 1g?
2g eprom will not work..
you need to find a 91-94 eprom and swap the pins from 7 and 14 I think and get DSMlink. it will be around 700 or so.
If you already have the afc, it has the capabilities to tune your 580cc injectors as well as a 2g mass airflow sensor which is a nice and cheap upgade. Youll need a logger though!
I personally use Tunerpro which is free and gives full timing/fuel control with a eprom burner ($100) and socketed ecu ($50) You can add stutterbox and many other features via hex editing.
I currently use the speed density files in the yahoo forums with good success and V3 aint got it
Nice car OP!
A 2g eprom will not work as stated above. You must use a 1g eprom only. As for the tuning tool, your safc1 should more than fit the bill at this point with your setup and injector size.
