Best setting for the Turbo XS manual boost controler for minimal turbo lag?
GSXpower
101
Jan 28, 2003
Nashua, Iowa
What do you guys have your manual boost controler set at to reduce turbo lag? I did it how the instructions told me, but I have some serrious lag. I have my boost set at 15 psi, and that holds well, maybe I have another problem that is causing the lag. Thanks
the boost controller doesn't effect the lag. i have a turbo XS controller on mine and i can set it all over the place and it doesn't effect lag. your wastegate might be hanging open a little bit, that would give you a little more lag. or maybe a boost leak. i would check for boost leak first. the best way to do it is presurize the system at the turbo inlet and listen for leaks.
You are probably right about it being a boost leak, or a cracked manifold. I am running the stock exhaust mani, I want a full tubular one, but will probably just get a ported evo. I will check for boost leaks tonight. I hit 15 psi at around 5500 - 6000 rpm.
The 1g manifolds are known to crack, mine was so bad that I could only get 11psi at 6000rpm, I put on a ported 95 and now by 3100 I get full boost.
