turboxs boost controler manual
WhyteSpyder
60
Jan 7, 2003
Sorry if I posted on the wrong forum, but does anyone have or know where I can find turboxs high performance instruction manual. If I'm correct, the HPBC has two two boost control mechanisms built into it. One is a ball and spring mechanism for large and coarse boost pressure increases, and the other is a bleed valve system for precise boost pressure setting. I have the adjusting screw back up almost all the way out and the bleed valve all the way out and I only see about 10 psi on my guage. Did i do this right or not? Neep help.
For ball-and-spring type boost controllers, you want to screw the adjuster knob IN to raise boost. This compresses the spring, and therefore it needs more boost pressure before a signal reaches the WGA.
For bleeder type, you want to OPEN the valve to raise the boost.
However, bleeder type MBC's SUCK.
.....Kyle T.
93 TSi AWD "TURBO4"
14b - 12.8 @ 108
I will try that, because right now I have the screw on the ball and spring valve back all the way out and the bleed valve out to about 1/4 of inche from the edge of the valve and I get only 10 psi. It boosted fast to about 10 psi then the needle stops moving up. Anoher question, do I have to set both the ball and spring valve (brass) and the bleed valve (blue) at the same psi or not?
  • Wanted 1g Wanted JMF intake manifold 1G
    Looking for a used JMF Intake Manifold 1G DSM. Race/street
    • nazagvr4
  • For sale 4G63 3 cracked Valve covers
    I don’t have 3 cracked valve coversI have sold some cracked covers in the past to guys that...
    • Dsm_canadian_mike
  • For sale 1g 1991 Talon TSI
    Clean Eagle
    • MasterLee
  • For sale 4G63 Go fast parts
    New Tial 44mm wastegate $315usdTurbosmart boost solenoid $80usd4G63 GSC S3 cams (280/280)...
    • Dsm_canadian_mike
    • nazagvr4
