Best place to wire gauge lights to?
dicion
45
Jul 20, 2004
Niagara Falls, New York
I'm planning on installing my first batch of gauges shortly, and I was wondering, from the people that have done this 100's of times, Where's the best place to wire up the power leads, so that they work on/off with the stock dash lighting. (on a 1G btw)
Now I know I probably could just find any of the leads to any of the the lights, and just run it parallel from there, But I would rather do it right, and tap in at the source. I've looked through all the wiring diagrams and i didnt notice a single 'source' for the lighting control... perhaps an experienced vet could enlighten me? (pun intended)
If you are looking at the harness for you dimmer, with the clip on top, the two leads are on the right for your lights. I forget which one is negative and which is positive. If you are looking to have your gauge lights be able to dim, then use this directly. Though i would just recommend using a relay and having dedicated power to your gauges. That will put less strain on the dimmer.
I used the light from the ashtray beside the driver seat.
Oh I also got a question, is the cigaret lighter (the thing that makes the cigaret smoke, not the orange ring around it) a power on voltage source?meaning that if you turn on the car there's power and not when you turn on the lights? planning to hook up a volt meter using that wire, I'm a non smoker
There is power at the cig lighter whenever the car is on (or at ACC or ON) and that's it. The light lead should only be used for lights because it never gets past 10.8 - 11 volts.
