best dsm 1/4 mile et on stock fuel pump
JohnTSI said:
Turbonetics manifold, GT35R, 720cc injectors, maft, 3" GM maf, SAF, keydrivers chip, spearco FMIC, B&M FPR, meth injection, custom controled shifted trans, 4K restalled convertor. On a 50 shot with very low timing it went 11.2@121 on the same setup, once we do a little more tuning it will go 10s on pump gas easily.
That's prett crazy considering a stock 1g pump can only flow like 60-75 lph at high pressures.
Is that setup using a seperate pump to supply the nitrous enrichment? If not you are one of the luckiest people on the planet. :thumb:
I have a 90 gst with 81k miles on it and just a big EVO III 16gt turbo with stock boost and a modded air box and thats it... on the highway i hold with stock sti's and modded 3000gt vr-4's and beat modded eclipses stock s4's and a whole bunch of other cars... every car run different... i think i got a very babied dsm though... people call it "THE ONE" because it acts so different from other DSM's
We didn't spray nitrous on the stock fuel pump. We realized we had a fuel problem befor that. And no it doesn't use a seperate pump.
How much meth are you injecting? That probably had a lot do with it. A stock 1g fuel pump isn't going to support that kind of power.
Enough to keep it from detonating at the time.
Top end is beautiful :thumb:
