Resolved Battery cables
xiprometheus
Jul 1, 2026
charlotte, North Carolina
Hey guys, so I have a quick question.
I managed to get my eclipse running for about a month when the power completely cut off, thankfully I pinpointed it down to being the battery cables, thing is tho how the hell do I get the positive battery cable out, I managed to unhook all the stuff for the negative wire so any help would be appreciated
Solution
Looks like replacing all the battery cable wiring worked, she runs like a charm now! Although those 4 white wires that lead to the fuse box might need to be replaced in the near future, so if anyone has a link for oem or aftermarket that would be sweet. Otherwise this thread can be closed
Which positive cable?
There's one (Black/Red) to the starter and 4 wires (White) to the fuse box. Two of those go to the Alternator fuse, one of which also that a stub (White/Red) to the 20A fuse #9 in the relay box for the AC and cooling system and two to the fuse box bus.
Here's the 2g positive battery cables connection to the engine fusebox.
This is common - power issues / battery cables. The factory cables go bad
Do your best to cut it out and re do the whole thing.
I use a junction point to tie in all the things that use / provide power to the car.
4 wires total
One for the battery
Alternator
Starter
Fuse box
Add many grounds
4 wires total
One for the battery
Alternator
Starter
Fuse box
Add many grounds
Thanks for the advice, I’m going to consider this if my wires all start going out, but right now I only want to replace the battery cables that connect to the battery itself. I already disconnected the negative cable from the ground above the transmission, any tips for taking out the positive cable since it’s on the starter?
Solution
