ECMlink Bad tune? Surging.
volkri25
60
Nov 4, 2008
Tempe, Arizona
This short log will explain it self. Bad surging at 4k rpm. Not sure if its a bad tune but seems like im the only one with this problem. Car specs ar in profile.
Have you checked to make sure your BOV isn't opening on you around that pressure?
I had to stiff of a spring originally. Now im running a 8 psi spring which is right in my vacuum range. Even at the lightest part throttle let offs I get the BOV. It also surged during part throttle with a 11 psi spring which was way to stiff for my application. How do you check a BOV when boosting 14 psi? Surging goes away in the higher psi range/higher rpm range.
Check to see how your air fuel ratio is
My AEM wideband is reading between 11.6-11.8 during the surge. This is at 43% throttle and ONLY 2.5 degrees of timing.
