Bad sounds after maintenance
bcjjones
509
6
Nov 3, 2011
Austin, Texas
New rebuilt head, new water pump, timing components, starter, battery, clutch, cv axles, and tune up. NOW it sounds a little bit like a rod bearing went out. Sounds like I swapped in a diesel. What's weird tho is it was running fine but started misfiring pretty bad. This was from one of the shops I work at to the other location. No knock or anything but a bad misfire. Parked it, worked the rest of the day. Started driving it home, still missing and about a mile from my house is when it started sounding like a diesel. So I pulled over and its sitting a gas station till I get off work today. No overheating, great oil pressure, timing is on poitlnt.
Hoping and praying that maybe its a bad fuel injector? Because it was missing pretty bad and from what I've been told and read, sometimes a bad injector can cause an engine to sound like its knocking or like a diesel? Any thoughts?
Ill be getting under and draining the oil when I can. Ill see if there's some nice pretty shiny metal in it. Just curious of how likely y'all think it could be a faulty injector?
Definitely check your injectors, spark plugs, and wires first. Rule out the easy stuff.
My manifold on my non-turbo cracked and made it sound like a diesel if that helps at all, but i doubt that'd cause misfire.
Timing marks are dead on. And I forgot to mention that after I stopped I could barely get it to start, and when it did I had to keep my foot on the gas to keep it running. It was missing really bad then, could barely get it to climb rpms
So you checked them after it started doing this, or they were dead on when you originally set it?
Well I checked it before I started driving home, technically before it started so ill check it again when I get off. Defininately not a bent valve do kinda curious what else timing would have to do with it? Detonation?
I can try to take a video for y'all if I get it started
I really wish it was a turbo! Then id be happy to rebuild the motor! So much money into what was supposed to save me money over driving my truck!
  • Wanted 6 bolt NT water pipe
    • chrisman287
