spyderdrifter
- 5,426
- 860
- Jul 11, 2009
Somewhere in,
Colorado
I'm posting this here because I haven't found conclusive answers during my search for answers. So this is to have the answers posted here for me, but also for others who may come across the same.
Anyway, I did a compression test a couple weeks back and concluded my rings are on their way out after the wet test yielded higher #s. Surprisingly my Spyder still runs rather well. I built a boost leak tester 2 days ago and did the test just to varify my ring conclusion and sure enough it did. No worries there. My car smoked a little white smoke at random points over the past 2 months. The smoke out put has increased since installing my Apexi exhaust (since I no longer have a catalytic converter). The point of this post is this: can my bad rings be the reason for the white smoke. My head gasket is good (only a few thousand miles. Less than 5k), and I'm not loosing coolant. I am running through oil little by little, but I'm sure that's because I need to replace the front cover crank seal, and it does leak oil only in this location. Also during the BLT, I found my BISS and BOV to also be leaking, but that was at 15 psi, and my boost on reaches 11psi max. Don't think either of those would lead to the smoking, but knowing that info might be handy. I'm replacing the rings and BISS at the beginning of August, but any input on this that'll assist would be great. Just don't want to replace everything and expect the smoking to go away, and then it doesn't.
Oh one other thing that I forgot. Can bad compression increase fuel consumption?
