Bad mpg
BLINKY619
1,211
4
Feb 26, 2010
SAN DIEGO, California
Ok people my car runs fine just did maintenance and still runs rich i mean ive done a lot to it even made a boost leak test didn't find any i had one but fixed it weeks ago it was the shaft seals i get really bad gas millage 2-3 days and empty's full tank im comfused no check engine light or codes...!
NO I DONT HAVE A LOGGER AND HOW CAN I CHECK IT WITH A VOLT METER? WHAT SHOULD I SET MY AFPR ON CAUSE ITS ON 43 PSI RIGHT NOW...! is that right? how can i know if my o2 sensor is bad when its not throwing any codes? thanks for the help
You'll want the AFPR set to 43.5psi with the vacuum line disconnected. Probe the signal wire on the O2 sensor with a volt meter, or you can check at the ECU using pinout #76. At idle it should be oscillating between about 0.2v and 0.8v. If it isn't then the sensor is shot.
A dead O2 sensor won't throw a code right away, but will when the FT's are maxed out. It's possible that it's dying and just inflating your FT's with a false lean condition which won't throw a code.
You might also want to take a look at your coolant temp sensor, although I have no idea how to check that without a logger. Perhaps someone can take a look at the service manual for a diagnostic procedure, because I don't have one in front of me right now.
ALRIGHT thanks for the help yea my coolant temp. sensor is new
i dont have my cas connected yet i haven't done the mod yet could that be causing my bad gas mileage
