lil corb
- 758
- 7
- Sep 7, 2005
Woodbridge,
Virginia
I am having this problem after periods of driving, when idling, my INT Temps are around 90-100*, my coolant temps are at 200-213* (even after adding Redline Water Wetter
) and I'll notice my MAF RAW hrtz will start to surge from 50hrtz to 20 hrtz, airflow per rev will drop to .23 and the car will peg lean on wideband and start to stall. The stalling doesn't happen every time though!
I don't have any other signs of a bad MAF as it only does this when idling after a period of driving. I also have my airflowperrev set at .29 as I have FP2s (272s) and I heard this is the target number for 272s. My ISC position is where it's supposed to be at 30ish
Could it possibly be heatsoak causing these issues? My airflowperrev at a wrong number? Or a bad MAF?
A couple of things to note is I only have the stock passenger side fan with a mishimoto radiator, no Emission lines at all with TB ports capped off, Dejon intake (only has recirculating port) with stock 1G bov recirculated and I also have my valvecover breather hose dumping off to the ground not recirculated back into the intake. (Could this be the problem?)
Any ideas?
Thanks
) and I'll notice my MAF RAW hrtz will start to surge from 50hrtz to 20 hrtz, airflow per rev will drop to .23 and the car will peg lean on wideband and start to stall. The stalling doesn't happen every time though!I don't have any other signs of a bad MAF as it only does this when idling after a period of driving. I also have my airflowperrev set at .29 as I have FP2s (272s) and I heard this is the target number for 272s. My ISC position is where it's supposed to be at 30ish
Any ideas?
Thanks
