Bad Idle Searched =-D
91TTZ32
Oct 24, 2004
Columbus, Ohio
Had the car re-aligned then 2 days later all the sudden out of the blue car has terribly low idle, and will stall comming to a stop. no major boost leaks, vacuum is fine, recirculating the BoV and the ISC also alright. What did i miss? cars a 95 tsi 150k miles. Any help would be awesome, thanks.
91TTZ32 said:
no major boost leaks.
What do you call "major boost leaks"? Any type of vacuum or boost leak will create problems. I would boost leak the vehicle and see what you find. This would be the first step. Also, check your biss screw. This could need adjusted or it might have gone to the DSM Gods. ;)
Exactly. Visual boost leaks do not count. Fill it with air pressure and listen. You can spray soapy water on places that might be harder to see, i.e. throttle body area.
Once you've completed the boost leak test, try backing out the BISS screw located on the top of your throttle body. This lets in more air and raises your idle.
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
