Spyder Bad cat?
streetlegends
319
9
Sep 7, 2005
Lawton, Oklahoma
Alright. My 99 has sat for a few years. I decided to hold on to it. No gas was in tank I am assuming it sucked out at some people. I put about 5 gallons in with seafoam. I even cleaned the MAF. I ease on the gas pedal and get stumbling. It cuts off. Now, after letting it run for awhile it doesn’t do it. The middle pipe is broken near the cat. Maybe that may be the issue. I can add a vid later today
What did you use to clean the MAF sensor? These MAF’s aren’t a design that should be used with the spray can cleaners so that could be an issue if you went that route. Also while it’s good there was no fuel in it it’s also possible an injector is sticking a bit until it warms up. I’d also pull the plugs and take a look at them and replace them since it’s cheap and easy.
