Back at it!
mikelv
566
12
Jun 17, 2006
Columbus, Georgia
After a long time of being idle, and trying to get my health back on track, it's time again to get this project done!!
I have just ordered the following parts to beef things up a bit and plan on adding a few more before I consider the 600hp+ project complete.
DSS Driveshaft
Custom Side Exit Exhaust
Jay's Alt Relocation Kit
Carbon Fiber Rear Hatch
Lexan Windows
Magnus SMIM
NO2 IC spray setup
Dual Walboro 255's
1600cc Injectors
Shifter Cable Bracket Spacers
ABS Removal
Misc odds, end, hoses, ect..
That's all off the top of my head, so later I will sit down and write a detailed plan of where I am, and where I need to be. It's going to take precision timing to get everything done in a controlled manor.
Those are a lot of expensive parts.
Good luck!
Hey I would like to buy those ABS sensors off from you if you are going to throw them away. Thanks
-Brian
Little update and change to my parts list. As you mentioned those parts were very expensive, so I made sure I set my priorities straight. I made sure I got just what I needed for now.
Driveshaft Shop 3.5" Driveshaft---yea!!!!
Fluid Dampr Crank Dampr--- must have!!!
New Samco Upper & Lower Rad. Hose Kit--needed!
MISC gaskets and fittings
All performance fluids, gearshock, brake, oil.
NKG BPR9ES plugs---extra set.
New cockpit controller for the MBC---must have!!!
I got to go to work, so I'll explain more later why I only went with this for now, compared to the rest of the list, basically, I've got everything I need now for my setup to max it's potential, ttyl!!!
Still working on a non-abs proportioning valve, I'll let you know.
