Finally getting it back together
muddfisher85
240
4
Nov 3, 2009
Lyndhurst, Virginia
Well I got a lot of work done on my talon yesterday. I got the new engine harness back in and new eprom ecu. I deleted most of the evap system and added an EGR block off plate. I put on a new IM since the old one had a shabby black spray paint job on it. I put a new valve cover on since the old one was cracked. Got my small 16g bolted up with my 38mm tial external wastegate. Im still waiting on more parts but it is coming along good. I have good hopes for this car. I will post more as I go.
I also installed 560cc injectors and AFPR. I also had to take the passenger door apart and had to pull the door lock because my dumb ass lost the key how smart was that. Out of all the dsms I have I loosethe key for the one talon I own what a pain in the a$$. Got two keys for $22 from a local lock smith, well I guess it wasnt as hard as I thought it was going to be. I will update more as I go
GST98 PR - Check the classifieds, you can usually find a valve cover in good condition on there. The valve covers sell for way too much new!
Been busy lately working on my relationship that I havent had much time to do any thing else. I did get my new tail lights put in and my water neck installed along with the radiator and the fan. I decided to put a high flow cat on instead of just deleteing it cops are real ass holes about that around here. Got to get some work done soon though its getting cold faster and faster. My main goal at the moment is the get the engine wire harness put back together and installed so I can see if it will run at least. Pray for this 6-bolt I seem to have real bad luck with dsm's.
also installed black top CAS, Chrome J-Pipe, and got the fuse box remounted and mounted a few intercoller pipes too. Looks like im a few short. O well figure that out when I get there. I need to just dedicate a weekend to tackle all of it. I hate my gs and have no desire to even fix it. It always seems to have some suspension issue. Fixed that junk 3 times now its broke again! Just junk and maybe I do rag on it a little but its a 420a it will live.
Ok I hate the cold but a have minamized my projects now all that is left is the awd talon so I will be making more progress when its warmer. I traded the gs in and sold the gst. Only progress I have made was pick up a set of 17' tires for my rims and I got an AEM fuel rail for it too.
