axles?
DSM "BISH"
241
Sep 10, 2008
Erlanger, Kentucky
hi i am in the process of removing my motor to do some things to it and im almost ready to pull the axles out and they ahve been out one time before to do some tranny work but i did not replace the axle seals. should i repalce the seals after pulling the axles out twice? or are they durable enough that they are okay? they only have about 5000 miles on them ### they were replaced with new axles and seals when the motor was taken out o be built about 3 years ago. and since then they have only been out once and now of course.
thanks
You should be fine. Even though the manuals say you have to replace them every time you pull the axles, that's kind of rediculous. Just keep an eye out for any transmission fluid leaking from the axle seals.
  • Wanted 6 bolt NT water pipe
    • chrisman287
