axel differences? 90 91-94
2gtalonman
226
Feb 4, 2005
Green bay, Wisconsin
I seen a thread on the differences but nothing about the axels, I see the trannys are different does that mean the axels are?
What axles are you talking about. Front, rear, FWD, AWD? :confused: The 90 and 91 axles should be the same for the awd. Late 91's they started 4 bolt rears and the rear axles have a 4 bolt pattern which bolt up to the cup of the rear. In 95 i believe, the bolt turned into a regular slipped in spline like the front slip into the hub. I have a thread right now about if a 2g rear will fit on a 1g rear with 1g AWD axles. Still trying to figure that one out.
James :laser:
