awd turbo gas mileage
If it is just vented, the car will run really bad, maybe even die when you let off the gas when the boost is on... this will make the car run rich. Does it skip, or bog down when you let off the gas?
Do you have a wideband? this will help tell you what's going on. If you bought it this way, it is possible it has been compensated for.
ya but not all the time, do you know where i can get the pipe to recirculate it
its got the afr gauge but the kid just had it in there not connected and it just lights up
I would try dsmgraveyard if they don't have it, try your local pull a part or salvage yard. It should make a huge difference in the way the car runs... As far as mileage, I can't really address that, but it should help that's for sure...
Connect it with some radiatior pipe amigo. Anything that has a seal really.. You'll be doing your car a huge favor. I cant exactly tell you how much worse your gas milage is giong to be but its not helping you at all, thats for sure.
