AWD tranny to FWD
4g63telantra
454
Dec 10, 2004
Toronto,
Im looking for a tranny (91-94) to put into my car (5spd turbo). I cant find a FWD tranny around my area. I know a few people selling alot of AWD tranny's.
What i would like to know is what would i need to make a AWD tranny fit into a FWD car?
you will need an awd flywheel an awd starterplate. You will also need to weld the bottom spider gear in the center diff. The output shaft needs to be removed from the trans and you must make a block off plate for the output shaft hole. If you were local I could do it for you.
