AWD Axle question
Yamahaulin
695
12
Jan 30, 2010
Bowling Green, Kentucky
I have a 2g AWD manual trans and i'm replacing front axles and i have lost the washers that go behind the axle nut, what is the part number for these washers and where can i get them.
The part number is MB109025. I doubt you'll be able to find them at a hardware store and after a quick look through the common parts stores, I find O'Reilly's may have them or be able to get them (manufactured by Dorman, part #618-037; easy way to check this is to call O'Reilly's with the Mitsu part # and have them cross reference it). They are the same washers used in all DSMs and virtually any other Mitsubishi vehicle so you can look at junkyards if you want to.
