AutoSlalom @ Scotia Speed World - June 27, 2007
Scott McIntyre
DSM Wiseman
309
44
Mar 15, 2002
Halifax, NS, Canada
Third time is a charm.
After being runner up the past two events, I finally met my goal and captured the fastest time of the day (FTD). But it wasn’t without it’s drama...
If you’ll recall from my previous event, I had a slight issue with a popped dip stick, engine fire, plastic dropped into the oil pan, and a separating crank pulley.
Well, by the morning of this event, I hadn’t yet got the car back together. In fact, the car had no exhaust, transfer case, driver’s axle, driver’s suspension, nor oil pan. So I worked all day and finally got it all back together with about an hour to spare before I had head out to the event. *phew*
After my first run I was trailing FTD by about 0.1 seconds. On my second run, I had brain fade and starting doing a second lap of the course, realized my mistake the cut into the finish. My time was wicked fast, but it was counted as off course (O/C) even though I inadvertently made the course longer for myself.
On my third run, I pulled it all together, dropped 0.5 seconds from my time and captured FTD. This time held for the rest of the event. Woo hoo!
Below are some pictures of the event. More pictures can be viewed here: http://spoon.org/pics/Motorsports/ASCC-Solo2-20070627/
(Greenfield event report coming soon...)
