2G automatic transmission dripping fluid from inspection cover
the_mork
2,619
26
Mar 10, 2008
Eau Claire, Wisconsin
I have a leak from my transmission that is causing me some problems. I have figured out at this point that the point where it is exiting the transmission altogether is from the small weep hole between the inspection cover and the transmission. I took the cover off and looked up there as well as I could and I snapped some pictures but they don't show anything at all and I don't have an easy way to post them since I'm not at home. The fluid lays along the bottom of the bell housing and as far as I can tell the torque converter is dry and so is the flex plate. Is there a common place for the transmission to leak back there and is there a way to fix it without dropping the transmission? The leak is bad enough to drip a drop every couple of seconds at idle and I can only assume that it is worse under power.
Any ideas? Thanks for the help.
I'm quite sure. It is definitely coming from the weep hole, I wiped everything down and ran it while on jack stands. I then looked up into there with the inspection cover off and I can see the fluid sitting along the bottom of the transmission in a thin stream. If it is a torque converter then that is going to be a PITA but at least less expensive than a completely new transmission.
YUP it will be. if it its might as well rebuild the whole transmission while its down LOL. thats what I did when my TQ busted LOL. check for metal shavings on the transmission oil (oil will look like if its sparkling with aluminum dust) as that is a sure sign that its going to need a rebuild.
  • Wanted 6 bolt NT water pipe
    • chrisman287
