Automatic AWD top speed
DSMLaser90
45
Nov 25, 2006
Raymond, New Hampshire
I have done homework trying to find the answer. No success in finding an answer, I don't know the top speed because, I due the posted speed limits, can anyone chime in on this topic?
"What is the top speed of my car?
Top speeds will obviously vary with the modifications to the vehicle. However, the top speeds for stock vehicles are in the following neighborhood:
- 1G AWD: around 140 MPH / 225 km/h
- 1G FWD: 140 MPH / 225 km/h
- 2G AWD: somewhere around 130-140 MPH.
- 2G FWD: some cars are speed limited to 130 MPH - see below for details
Is there a rev limiter on my car?
As far as is known, the ECU will stop fuel delivery on all the DSM cars at 7500 RPM.
Some 2G FWD cars have a speed limiter which cuts off fuel at 130 MPH. This is because the stock H-rated tires are only rated up to 130 MPH. Replacing the tires and performing this procedure will eliminate it. Warning: you do this procedure at your own risk. There is some information that this fix only works for 1995-1998 cars. "
1000 AAQ - Make & model info
I have seen 125 indicated in my stock 92 AWD AT car (on the track, of course) and 135 in a mildly modified (16g, 550s, super sidemount w/ hard piping & 1g BOV, 255 & 50 PSI FP) 95 FWD AT TSi under the same basic conditions. I wouldn't want to try & go any faster in the 2g, as it felt highly unstable at that speed. The 1g felt much less skittish and inspired confidence at that rate. I may check the potential top end in it again once I've finished the new engine, but it will definitely be under controlled conditions as before. I can't imagine trying to do something like that without the security of a closed course!
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
