Autocross - First Time
96DsmTunr
105
Apr 11, 2008
akron, Alabama
So it's warm again so time to put the Jeep away and pull the car back out. I registered for an autocross event next weekend and I wasn't sure if there is anything else I can do to my car fairly cheap and fast by then. These are my current mods. Thanks guys. By the way I'm a 2g tsi awd
Tein Type Flex with edfc
Camber adjusters
RM swaybars
Megan tower braces
Apexi power intake
Apexi N1 exhaust/downpipe
Dejon Tool upper intercooler pipes
NGK plugs
MSD Ignition wires
Poly motormounts
Fluidyne radiator
HKS blow off valve
Upgraded pads and crossdrilled/slotted rotors
Toyo proxes 4 tires
Handfull of gauges
Greddy turbo timer
Camber adjusters
RM swaybars
Megan tower braces
Apexi power intake
NGK plugs
MSD Ignition wires
Poly motormounts
Fluidyne radiator
HKS blow off valve
Toyo proxes 4 tires
Handfull of gauges
Greddy turbo timer
You'll find out its not about having power, its about having spool. If you don't have intercooler piping or a fmic I'd suggest doing that, a 14b turbo if your still on the stock t25 and a MBC. Should add a little power to the butt dyno.
Yeah Autox is not so much about raw power as staying in your power band and knowing how to brake and shift effectively. It's a lot more about the driver than the car. Make sure your have good wide tires.
The car hasn't been out on the road for a long time so I will be getting the camber and all that readujusted. What should it set it at? Any suggestions?
Driver Mod x2.
Instead of MSD wires, go with the NGK wires, cheap and real good. Also SS brake lines are a good one time upgrade. They run about $100 and new brake fluid will really help. The fluidyne radiator is nice but for the money, the Mishimoto with new hoses is a good deal, too.
You'll aslo want to consider changing your tranny, transfer case and rear-end fluid.
