ARP flywheel bolts
JayB12
544
Jan 12, 2009
Philipsburg, Pennsylvania
I bought an ACT clutch kit w/ the streetlite flywheel. I also got ARP flywheel bolts. I've looked this up already. The arp bolts are for a Supra but fit the 4g63 but they are slightly longer. I also read that there is a thickness difference in the flywheels. I'm not sure about the one I bought as far as differences in thinkness. Should I order this kit? Forced Performance Turbochargers: DSM Aluminum Flywheel Hardware Kit
I'm not sure what to do here. I'm having a shop install the parts because I work 7 days a week and use this as a DD and cannot have it down for many days.
The ACT flywheel is not aluminum. The FP hardware kit you linked to was designed specifically for aluminum units.
Use the supra ARP bolts. I was using them with my ACT flywheel when my car was a 5 speed and I'm also using them now that my car's auto. It's really easy to cut them down if you have an angle grinder and a vice. I even made a quick tech article about it when I did it.
Edit: here's how I did it: http://www.dsmtuners.com/forums/art...rp-supra-flywheel-bolts-cut-shorter-4g63.html
I use the ARP bolts with my streetlight, got them from EPSI. Never had a problem installing them. Been using them for 2+ years now without any issues.
Sent from my Atrix 4G using Tapatalk
Your link in your write up and part number is for MR2/Celica bolts with a 5sfe, not Supra. Is there a difference or are they the same bolts for all toyotas?
