apexi turbo timer q
jmartinez1228
359
Feb 20, 2004
Rocky HIll, Connecticut
Ok i have the turbo timer just about completely hooked up and it works fine. I have a few questions
1. on the intructions for the o2 sensor wire its says to put it on pin 2 we did that and when we put the timer to read a/f it blinks red and green. So where exactly is this white wire supposed to go. I looked at a ecu pinout and found pin 2 but its not working. what could be wrong?
2. The o2 portion of the timer is reading 4.5 and fluctuates to 4.49. what exactly is this telling me and how do can i use it to my benefit(instructions were in chinese)
3. what is my voltage supposed to be at?
i tried to do a search but mostly found wiring for a 2g.
1G ECU Pinouts, Horizontal Layout
Pin Connection Pin Connection
101 Ground 106 Ground
102 Power supply 107 Power supply (to MPI Control Relay and ??)
103 Battery backup power supply (constant 12V) 108 Ignition switch - ST
104 Neutral safety switch (AT only, grounded in MTs) 109 Ignition pulse detect (tach)
105 Wastegate solenoid valve 110 Ignition switch - 1G
51 No. 1 Injector 60 No. 3 Injector
52 No. 2 Injector 61 No. 4 Injector
53 EGR Control Solenoid Valve (90-93 CA only, 94 all) 62 Purge control solenoid valve
54 Power transistor for #1 and #4 coils 63 MPI Control relay
55 Power transistor for #2 and #3 coils 64 Check engine light
56 MPI Control relay 65 Air conditioner relay
57 Fuel pressure control valve 66 MPI Control relay
58 Coil "A1" for idle speed control motor 67 Coil "B1" for idle speed control motor
59 Coil "A2" for idle speed control motor 68 Coil "B2" for idle speed control motor
1 Self-Diagnosis Output 13 Control relay (Fuel pump drive signal)
2 Diagnosis/Data transfer select terminal 14 Air flow sensor active filter reset (idle switch)
(switch with 6 if using a 91-94 ECU in a 90 or vvs)
Stock wire color - Green
3 Turbo gauge 15 EGR temperature sensor (90-93 CA only, 94 all)
4 Oxygen Sensor 16 Barometric pressure sensor (MAF)
5 Power steering oil pressure switch 17 Sensors ground
6 Idle position switch
(switch with 14 if using a 91-94 ECU in a 90 or vvs)
Stock wire color - Green/White 18 Vehicle speed sensor (reed switch)
7 Air conditioner switch 19 Throttle position sensor
8 Intake air temperature sensor (MAF) 20 Coolant temperature sensor
9 Detonation sensor 21 Crank angle sensor (RPM)
10 Air flow Sensor (MAF) 22 Top dead center sensor
11 ABS control unit (AWD, ABS only) 23 Power supply for MAF sensors (5volts)
12 Ignition timing adjustment connector 24 Sensors ground
