Apexi Turbo Timer Malfunction
JeanDSM
405
Jun 23, 2004
Yabucoa, Puerto, Puerto Rico
I bought a Apexi Turbo Timer last year and it worked great but a few weeks ago it stop working. It Still reads the battery volt. O2 volt. A/F ratio but when i turn off the engine the TT dosent works. I reconected just like the intructions says. Whats wrong?
You had to of messed with something. Did you hit a button by mistake? Are you sure your parking brake is up? Did you check all of your connections?
I followed the instructions step by step. Installed and cheked 3 times. Check the brake wire and the brake signal is good doble check the ignition wires power and output. chek the O2 signal wire. The TT only has a joystick and i set it up for 1 minute. Still dosent works.
