A'pexi AFC neo
PattyG
41
May 20, 2006
Grand Island, Nebraska
A'pexi AFC neo
Found it while looking around on A'pexi.com Has Anybody tried it?
Will it even work with DSM's? Looks pretty nice to me.
it's supposed to be a safc2 and a vafc combined with color and all that. I plan on getting one in a few weeks, not for my dsm but on a maxima and if I like it I'll get one for my dsm it'll work for tegs cause it has the vafc settings.
I really like it. Looks nice and sounds great and will provide better tunning ability.
Some one using it yet let us know!!!!
ok so yeah, i guess im the first dsm'er to have a AFC NEO.. i bought it on friday at Kinetic Motorsport, and got it installed at ZENSPORT in syndey vancouver island BC.
ZEN has a dyno dynamics and did a great job installing it, and tuning it.
i installed 550cc injectors and 255LPH pump with nothing to control it...
so i did a dyno run before it was tuned at it was 245HP at 23 PSI
and after his fine tuning on the dyno i got 260HP at only 17PSI....
not bad, 15HP and 6PSI drop!!!
still needs more tuning after i get a electronic boost controller... my mbc isnt working right and just stops at 10 psi and creeps up slooooowly to 17PSI.
what else can i say about it... it has 16 points of adjustment not 12 like safc2.
the increments of adjustable points are 50rpm. yes 50rpm... not 200 rpm.
so you can set it at 1k 2k 3k 4k 5k 5050rpm 5100rpm 5150rpm etc... for all your problem areas...
you pick your colors and funky screensavers to customize yet another thing in your ride.
pics of item in car and dyno results up shortly
Ive got a neo on order and its suspossed to be in on wednesday so when i get it illpost on it to let you know how user friendly it is since unluckily mine want get dynoed. Wish it could but i would probally be ashamed at the way its running rite now.
After reading up on the Neo I found out that you can only have 1 saved map as where on the S-afc II had 2 saved maps....so if you dont mind only having one map then the Neo is the way to go.
