Anyone know what size these bolts are?
SuperSleeper
204
Jan 27, 2004
Farmington, Minnesota
I'm sure if someone has a tech manual, they'd be able to find out. It's the two bolts that hold the shifter cable to the block, so it doesn't flop around. A friend's shift linkage felt really weird, and we discovered it's because the bracket is completely discnonnected. It's a 97 AWD. I'm going to try and fix it tomorrow. Any help in the matter would be much appreciated. Thanks guys!
they are 8x1.25mm and are about an inch in length when measuring the threads. They have a 12mm hex head on them. good luck!
