Anyone have experience with the greddy full auto turbo timer?
G9S6T
120
Mar 31, 2007
miami, Florida
My timer just stopped counting down. Do you guys have any experience with this turbo timer. I disconnected and connected everything and I dont have the e-brake wire hooked up but It worked ad good 4 months with it not hooked up. Any suggestions? Thanks!
I have experience with the very first and the latest one, and they are still being used as we speak and the old one has been swapped out from so many cars. I'm actually shocked it still works. The timer should be fine. Is it turning on? If so double check your wiring, perhaps the connection is bad, bad ground, etc. These things don't have a high failure rate, just high installed wrong failure rate. Good luck.
It turns on every time and It reads voltage. Would a bad ground make it not count down.
I have the Blitz FATT, I had a similar problem. Mine was turning on and reading voltage, but would not add time to itself, and only time down if I preset the time. My alternator was on it's way out the door. You might wanna get that checked, otherwise maybe you can try resetting the unit.
on the back of the turbo timer there is a really, small, slide style switch.... like the size of an led... this switch de-activates the count down time feature so you can mess around with the settings... you might have accidently hit the switch....
I changed my alternator 4 months ago. My timer is set to wait a minute count down before turning the car off but as soon as I switch the key back the car shuts off. That little switch in the back, Ive tried turning the car off with the switch both ways and still no results.
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
  • For sale AEM Series 2 Total Control Plug And Play Stand Alone ECU For Sale
    I am selling my AEM Series 2 plug and play, fully programable, stand alone ECU. I had bought...
    • LSM
  • For sale 2g 2g passenger side PW switch
    Passengers side PW switch. Good condition. Message 702-741-6987
  • For sale 2GB Factory Owners Manual For Sale
    I am selling the factory owners manual warranty info booklet, and maintenance booklet, all in...
    • LSM
