Anybody know of any complete gasket sets?
tsidrift1
819
5
May 12, 2004
Decatur, Illinois
I am waiting on a shortblock form engintecs, I have been getting pricec on new gaskets and such. I saw all the gasket sets on ebay going for like 90.00 bux. I am going to use OEM oil pump gasket and OEm head gasket, but the rest of the stuff i can get just at the local autozone or wherever. I thought I would just ask first if anybody has had good luck with any full gasket kits.
Let me know,
Anthony
Fel-Pro from the auto parts store. Fel-Pro is definately a top choice and the goes for mitsu oem but thats more expensive and same quality, but I would recamend a mitsu stainless steel head gasket its worth everypenny and can be reused.
Good luck
Unless you are running a 100% stock engine. I wouldnt suggest using a Fel pro gasket. They tend to not like boost. However the Mustang guys can use them all day long. Just my .02, but if you do decide to go with the Fel pro. Dont be surprised if you are changing it again soon. I suggest a good OEM (much better than Fel pro) with head studs or an OEM metal depending on head surface.
Wendy
I'd go with a Cometic or Mitsu metal head gasket and some ARP head studs. Well worth the money. Felpro's are alright for a quick fix, but I wouldn't reccomend them for long time use.
I know what headgasket I am using. I am using the mitsu 4 layer metal gasket. I am wondering about complete engine gasket sets. I don't want to buy every gasket seperately. I was wondering if any body knew of any companies that sell a good complete engine gasket set. I am talking like intake, throttle body, exhaust, valve cover, etc all in one set.
I know what you are talking about. I did the same as you, and bought a GOOD head gasket (Cometic in my case) and other things, like valve guides. But for all the miscellaneous other gaskets, I just bought a complete gasket set from Topline. It had everything I needed, like the intake gasket, throttle body gasket, rubber seals for camshaft ends and plastic front cover, etc. Surprisingly, that gasket set even came with a multilayer copper exhaust manifold gasket. The Topline gasket set worked well for me...
http://www.importperformanceparts.net/imports/mitsu_index.html
The complete gasket set will also come with all the seals you would need. In the long run, it would end up running you less to buy the set, and head and oil pump gasket of your choice as well.
Mike
This what you after?
$244.00 with cometic HG, $146.00 without it.
JAM~Cometic HP Engine Gkt Kit, +500whp 6bolt
BRAND NEW!
This is our JAM premium engine gasket kit, complete with a Cometic HP performance head gasket and our JAM~Premium valve guide seal set. Now you can get ALL your performance gaskets at one time and in one great kit! Fits 2.0 4g63 6bolt turbo engines. +500whp use rated
*Your will get all of the following items in our Great! kit:
*Cometic HP head gkt, 86mm
*Valve cover gkt
*Intake manifold gkt
*Exhaust manifold gkt
*EGR gkt
*O-rings
*JAM~Prem Valve Guide seals
*Cam seals
*Thermostat housing gkt
*Spark plug tube seals
*Throttle body gkt
*Exhaust pipe flange
*Water outlet gkt
*Semi-circular plug
*Pan gkt
*Oil pump gkt
*Rear crank seal
*Rear seal cover
*Front crank seal
*Oil filter housing
*Balance shaft seal
*Oil pump seal
*Water pump gkt
*Oil pump o-ring cover gkt
*Strainer gkt
*Crush washer
*Oil cooler bypass valve washer
*Oil jet washer
*Oil pump o-ring
*Water pipe o-ring
*Timing cover seal
https://www.jacksonautomachine.com/html/shopping/list_section.cfm?sectionId=29
the gasket set on ebay is from rock products www.rockprods.com
It is a complete set every thing but the turbo gaskets it is the only set I know of that coms with the front cover (timing cover set)gaskets bu thr gaskets are cheap and unless you use 3 tubes of rvt sealant they WILL leak
I realy like there valve cover, exaust, and valve stem seals
