Any intake gurus? I need quick help
EclipseyGSX
May 4, 2004
Duluth, Minnesota
http://www.tgilmore.com/talon/dumptube.html - I am in the middle on cutting up my bov dump tube and it seems when disconnecting the hoses from the main intake tube I accidentally disconnected the wrong end (it fell off somehow) of one of the three tubes your suppose to remove.
So heres the step by step what happened - I removed the tube from my BOV and I removed my airbox/MAS thing - I removed the clamp on the turbo also - next I was going to remove the three small tubes from the main intake tube (the one that connects between the MAS and the turbo. When I was doing this, I got to the last one, and noticed one of them wasnt connected on the other side of it - it seems to be some kind of sensor or something - the tube itself is about a foot long, on the sensor end it has a rubbercoated metal screw hole that wasnt screwed onto anythign - its part number is k517698 - 4823 - heres a modified picture from the tgiLOLre.com site - the tube im refering to is arrowed in BLUE -
Thanks for any help, I know if theres a intake master out there that can answer this q - its on this forum- u guys are the greatest, thanks again
1995EclipseyGSX
MN
That goes to your stock BCS. All you do is look underneath where the intake tube lies and there will be a small box with 2 nipples, put that tube on the nipple that has no tube and your set. Let me know how it works out. Theres a picture of it on this site http://www.vfaq.com/index-main.html you can also remove the BCS restrictor so you can get like 2 more pounds of boost so you can do that while your down there. Let me know how you make out.
-ANdrew
Sprry about that link when you go to vfaq go to turbos link up top then scroll down till you seeBCS restrictor removal, then click on that and that will bring you to the page
-Andrew
sorry man, no luck - cant find any 'little box with two nipples' - I found another little sensor box that looks similiar to this contraption where you told me to look, but this one the little thing u told me to take out with a screw has a hose on it - anyways, could anyone who knows this car inside n out help me here? where do I plug in this crazy thing, i miss driving! Thanks for the help m8
95EclipseyGSX
The hose that you are asking about doesn't go on the nipple where the restrictor comes out, it goes into the nipple above that one there should be 2 hoses connected to that sensor box. The top one is the one you need, not the bottom. The bottom one has the restrictor in it, the top one goes to your intake.
