Any Help? (may be wrong fourm)
Skibble
Oct 27, 2009
Whitewright, Texas
Ok I have a 1995 Eagle talon TSI and today i was driving to work and my factory boost guage quit working and then as soon as it did my car keeps cutting out when cruising and it stumbles at Idle.I'm sorry if this has been covered but i've searched for the same situation and nothing came up.
I'm a real newbie at the dsm any help would be appreciated.
First and foremost always use descriptive titles when creating threads, it helps us to help you.
I would suggest starting out with a boost leak test, these are very easy to do and are an incredibly important maintenance procedure that is almost always overlooked by shops and owners when it comes to turbo cars. You can use the search feature to find more information or look here for an article on how to make one. I'm pretty sure out turbo inlets are the same size as evo turbo inlets if you use the rubber ring that sits at the bottom of the intake snorkel or if you push the tester up onto the compressor cover.
http://forums.evolutionm.net/evo-how-tos-installations/339529-how-boost-leak-tester-5-02-a.html
Otherwise I would suggest a malfunctioning or disconnected MAF.
Edit: I completely forgot to post a link.
