Another Idle surge question
dthquazi1
867
Jun 18, 2003
I got idle surge bad. It doesn't stall often however when my car is rolling it will idle fine. If i am a very slight hill and i let the brake off it will stop surging once i start roling forward. Has anyone heard of this?
You must have an automatic. You should still check out that link I posted above. The reason I believe it's one of the problems in that link (probably the idle switch) is because you say it only surges when you're absolutely still. The ECU determines that you're idling when your idle switch is triggered and you're not moving. Let us know how your results turned out after you've done the tests in that link.
Did you even read the rest of that post? The thing I tried to stress most was that the idle switch should be tested. Before people start buying new ISC's and TPS's etc, they should check their idle switch. It's really easy to check. It can and will totally fux your idle if it's not calibrated correctly.
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
