another 16g question
nobuhiko takada
Mar 21, 2004
milford, Connecticut
ok so i have the 16g and its getting old.. was just wondering
if i can mount a big 16g and what will i have to do in order for proper instalation?
will it bolt right up?
DAMN NEWBIE USE THE SEARCH FUNTION THERE IS OVER 200+ THREADS ABOUT 16G's. YOU ARE NOT THE FIRST TO COME UP WITH THESE QUESTIONS!!!!!!!!!!!
http://www.dsmtuners.com/forums/search.php?searchid=457778
If you have a manual 1G it is a direct bolt-on, if you have a auto 1G you need a new manifold, coolant lines, return lines, and gaskets.
i have searched and even the link you gave to me was bogus... check it yourself... so next time you wanna go running around like your some tuff guy cause you got a turbo,, and know some crap about a manifold... DONT unless you get the right info,,
oh yeah YOUR MOTHER!!!!!!!!!!
stop being whiney girls..
a b16G uses the td05h comp housing and a 7cm [ most ] turbine housing.. so yea, it will bolt up to a stock 1g. just reuse all of your parts and swap the turbo.. cause essentially its the same as a 14b but with a bigger, lighter comp/turbine wheel
DSMSPYDER99 dont take this the wrong way but........... i love you :laugh: :laugh:
that guy got owned and i couldnt have said it better myself :laugh: :cry:
Kimbo Slice!!!!!!!
Kazushi Sakuraba!!!!
Wanderlie Silva!!!!!!
Nobuhiko Takada!!!!! <-------
Quinton Jackson!!!!!!!
Your Mother!!!!!!!!
nobuhiko takada said:
Kimbo Slice!!!!!!!
Your Mother!!!!!!!!
i dont get it? :confused:
