Another intake question
FreStylMotoX01
345
May 20, 2004
Chester, Vermont
ok i bought a dejon tool intake from someone on tuners. no it is just the straight one with BOV Return but what about the two other hoses at the top of the pipe before the MAS. do i need to hook those back up? what will happen if i don't? thanks in advance
-Jon
One hose comes from the charcoal canister and the other hose comes from your valve cover. If these hoses are not connected to the stock rubber intake right now, I assume that they are just venting to atm? You don't need to hook them up but you will have to plug the tubes on the intake. I would hook them up but that's me.
They are/were hooked up to the stock intake piping. the car doesn't get driven that much right now so i just figured i would start putting the new intake on. so i haven't run the car without this yet im just checking before i put this intake pipe on and don't have anyway to connect them.
if they dont get hooked up or at least the one to the valve cover i am sure that oil will go into the intake pipe and intercooler
1. If you dont hook up the carcoal cansister line it will throw a code.
2. You can run without the V/C line and just put a filter on the nipple but........by pulling air out of the V/C AKA the crankcase you are putting negative pressure on your piston rings thus creating a better seal. I put a small fuel filter from pepboys on this line to prevent the oil from making it to the intake, but do whatcha like :p
