am i boosting like i should?
Alex Bland
666
3
Jul 2, 2008
Seabeck, Washington
alright i get insurance on my car soon woohoo imma beat on it for a while then rebuild it all. so before i do mbc and and a little fun i think i have a little problem. When i do my blt it holds the air for maybe 5 seconds. and ive fixed all the ones in the injectors, Intake, tb. so im left to thinking waist gate, smic, or bov? heres a video of my car making boost. well its trying too.
YouTube - VID 00001-20100415-2028.3GP
i rebuilt the turbo, theres no shaft play, i rebuilt it cause the o-ring inside was bad and was causing smoke. and now i know my valve seals are also bad
so it seems like it hold only 5 psi of boost? are you on the stock boost controller still? maybe your wastegate is going bad.... if you did a boost leak test and fix all the boost leak....
Check your wastegate actuator arm to make sure it's still on the turbo, and check around your flapper for cracks. Do you have any big exhaust leaks? I had an issue similar to this when my turbo was separating from my exhaust manifold as well.
