alternator help
kerbassis
Jan 30, 2005
stroudsburg, Pennsylvania
I installed a new alternator in my 94 eclipse gst. For some reason some of the wires came loose but i can't figure out where they go. The alternator charges to 12+ but then steadily starts dropping. I think its the charge wire but im not sure. If any has a wiring diagram or pic that would be great thanks.
i dont have a diagram but its one wire that bolts up to it and the other wire is a plastic connector u cant get that wrong.
the charge wire has and I-screw(i think that might be wrong of what its called) but u bolt it on the stud poking out...and then the plastic cap goes in the hole...just be sure not to ground urself out when tightening the alt. back on good...i blew my fusible link when i accidently did it.... :( it sucked could have saved myself 1.89 if i would have had an extra light... :rolleyes:
