Alternator Bolts
saxrulez
83
Feb 4, 2004
Fayetteville, North Carolina
I need the part numbers for all the nuts/bolts that hold the alternator on. ESPECIALLY the metal piece that the bolt goes through to adjust the tension.
Thanks.
I could use the same thing. Are you talking about the long skinny bolt and nut that hold it to the block? If you find anything out will you post it here b/c i need one too. As of right now just my belt is keeping my alternator on OMG
Thanks.
What for? Goto a junkyard and just pull them all off. There are a bunch of cars with 4g63's and those parts are pleantiful.
if you could name some it would really help me out :)
I'm not even sure where the junkyards around here are...Guess I'll try and find a phonebook and start looking.
  • Wanted 6 bolt NT water pipe
    • chrisman287
