Altenator issues..
Kod
289
Mar 29, 2011
Kingston, Pennsylvania
I changed the original altenator in Jan. 2011 then that went bad and was replaced again in Dec. 2011 / Jan 2012. Both of those altenators just flat out stopped out putting volts but now this current one is now overcharging... Is this just a string of bad altenators or can something else cause this?
I've changed it out both times but never took the radiator fan out which would probably make it much much easier to do.. any help is appreciated thanks.
Are you getting remanufactured ones from advance/auto zone? They're crap and don't last long, and often don't work right out of the box. I've had the same problem, I'm either going to just buy a new one (kinda steep at $325 tho) or look for a 90amp one from a spyder gs at the junkyard
Edit: taking the radiator fan out makes it a thousand times easier, you can just lift it right out
Thanks... yea I use to just always fight it out the bottom and fight it back up from the bottom (what a night mare...) but I never had issues with REMANS. The one I'm using is from cee kay brand USA. They don't even have another one for me and can't even order one since their last one was 12-21-11 (which was me) LOL.
So gotta wait to talk to the manage to see how this is gonna work since I can't buy it somewhere else without the core and they can't give me a full refund without that altenator..
A guy was trying to find a match that would work but couldn't find one with matching amps or prongs for plug.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
