almost over heated
fbiman6280
Oct 3, 2009
Spokane, Washington
I have a 95 eclipse 2.0l turbo, stock internals, wlaboro fuel pump, 16g turbo, Last night it started to over heat, it runs fine no check engine light, I noticed the oil seems a little thinner than normal and smells like gas i cant really tell if there is antifreeze in it, the coolant level is full after it cools down, it does not smoke out the exhaust like a blown head gasket, it appears that the coolant is flowing when its runnning the fans come on, no air bubbles in coolant nor does it appear to have oil in it
wow thats weird top off with antifreeze/water when its cool if it happens again pull over and check it out if it seems like nothings wrong and no weird sounds then check sensors, interested in what it might be
