All lights are flickering!
Misterio
134
Mar 16, 2004
pittsburg, Texas
hey guys well starting yesterday all lights in my car, most noticable my headlights are flickering pretty bad when the car is on. the car idles a little bit low as well. one time that i tried to start it, it almost did not start. what could this be? my friend thinks my alternator is about to go out. please help me out, thanks!
I experienced the same flickering a few years ago. It turned out to be a bad alternator, so I had Sears Auto replace it. Then, almost exactly a year later, the lights started flickering again as I was driving down the road. It would only happen periodically, but I had Sears replace my alternator under warranty, even though their tester said the alternator was fine. I still had two mechanics (one was my uncle) and an Autozone worker say that the alternator was definitely bad, so Sears grudgingly did it. Then my flickering problem was solved.
To be sure, you can take your car to any Autozone and they will test your alternator for free.
Test the battery also. You'll have the same symptoms with a bad battery as with a bad alternator.
Like stated above, the alternator and battery are the first things to check and AutoZone will test both for free. Also check that your terminals are in good shape and all connections are clean and tight.
